Greg Elmassian
Guest
One answer to one question, why not screw track down and unscrew if there is a problem.
The reason not to do this is normally the rail is pulled from the "spikes" that hold the rail in place and often the ties are damaged.
I've seen lots of ruined track where it just was discarded. A wealthy gentleman near me had narrow concrete curbs laid to place LGB track. It was in a sloping area that had several "putting greens". The area had been recently graded, and there was no reinforcing bars connecting the concrete "curbs" that the track was laid on.
As time went on, the concrete settled, and the track was screwed down every section (using standard LGB sectional track). After a few years, 40% of the track was damaged to the point that rails were completely out of the ties, or gauge was bad enough to cause derailments.
To make matters worse, they had removed the screws through the ties into the concrete and put glue over several ties, so instead of just ripping out one tie (the one with the screw) 3-4 ties were pulled away from the rail, and now even more issues.
So, trying it to see if it does not work needs attention to change before the track is damaged. Many people do not catch the situation soon enough.
