ntpntpntp said:
A quick question if I may: from previous postings can I take it the volume knob is not mandatory with the XLS decoder? It doesn't need the connector pins bridging or anything like that, if no knob is used?
KentKeith asked me to check over a bunch of (believed dead) decoders a little while ago, including an XLS for which so far I've only tested that the motor drive works. If the volume knob is not required (I should check CV200 to set the volume?) then I only have to worry about plugging in a speaker to test the sound? Is there a "sound on/off" function key that also needs to be on?
I really must study the manual for the XLS (not used one myself yet).
Cheers
Vol control knob not mandatory, but I find in practise it is more benficial to have one saves time if wanting to reduce vol quickly.,
Nothing has to be done if Vol control is NOT used.
Check CV200 to ensure that it is not set too low, cant put my hands on an instruction book at the mo but CV value of 64 rings a bell for FULL volume
From memory F1 may be the on / off function
Unless of course the functions have been altered in which case it may be worth doing a factory reset on the decoder, if the decoder is thought to be faulty then this is probaly the first action to take anyway!
