Mobi
I have recently bought a used RhB Ge 2/4 loco from a well known shop.
In its underside "Made in West Germany" was written. I knew it was an old loco but did not realize it is ~40 years old considering Germany unified in 1990.
I have put a video of it here.
My only other track powered loco is basic Stainz (which I bought new 12 years back). I run analog track with LGB 1 Amp controller. I noticed this RhB loco does not even start moving until I put regulator over 2 mark. Where as Stainz starts moving before 2 mark. I guess its power requirement is higher than Stainz. Also, on max 4 mark, Stainz runs like a horse where as RhB is considerably slower even at max voltage. Is that expected? My controller is the basic one that came with LGB starter set.
I also noticed if I put both Stainz and RhB in the track, Stainz moves but RhB stops! I expected both of them to move. It seems 1 A current is not enough for both locos.
There are 2 holes in front & rear of the loco. If I supply battery power thru wires, the wheels rotate! This means, this loco can be converted to battery power without actually opening and tinkering inside - if I put batteries etc. in an attached wagon.
Is there any ready to use plug to fit into those holes? If yes, what are these plugs called so that I can search on internet and buy.
The loco is very heavy! I ran it for 4 hours continuously and motor block still feels cold to touch where as in Stainz I can feel slight warmth after running for couple of hours.
