trammayo
Trackshack have a clearance sale on at the moment (at the time of commencing this thread) and, although I had looked at building my own from scratch, I thought I would purchase it and save time and effort!
Called Dotti (because of the rivet heads maybe?) it is a freelance design IC loco. I cannot see it as currently listed on IP Engineering's site but the model is cut from plastic sheet. Just what type of plastic I wonder? Maybe High Impact Polystyrene (HIPS) but there are no clues anywhere!
Costing just £51 + a small postage fee from the I.o.M, I think that's a good deal.
Here's what you get for you money (or what I got at least);-
Two sheets (one 300mm x 175, and the other 300 x 85) with the components just held in with the odd tabs in the milled outlines.....
... diecast components = 4 Dummy axle boxes, exhaust/silencer, air intake cap, handbrake wheel radiator framework, and the coupling castings x 2 .....
There's a bag of components which include the motor, axle bearings, a pair of SM32 wheelsets, a pair of axles plus four nylon spacers (for converting to 45mm), worm and wheel gears, two brass pins for the couplings, a plastic sprue with dozens of rivet heads, some miscellaneous fixings - only two identified at this stage, a piece of ribbon cable to seperate for the electrics, and two D.P.D.T, switches (On/Off or Fwd/Rev.).
So, no battery box (has featured in the instructions and, indeed, no mesh for the radiator grille as also shown in the sheets.
The we come to the "Instructions" which comprise six sheets. It is intimated that it is best to follow the sheets to ensure things are done in the right order. To facilitate this, I have numbered the sheet myself!
So that's as far as I have reached at the moment. The cover sheet forms part of the instructions and mentions that the whitemetal castings do contain a small amount of lead so it advised that hands are washed. I might also add that I used barrier cream when handling or working with lead.
So more to follow when I regain control of the kitchen table!
