Wobbleboxer
I was watching a YouTube video earlier where the chap was fitting tail lights to HO wagons and using a current pick up method I'd not seen before. It involves a loose fitting spring over the axle of a wagon, shorting the axle to a wheel on one side and soldering the pickup wire to the spring. Repeat on a second axle for the return connection. Watch the video below from about 5 minutes to see it in action. He also talks about the benefits of this method over push contacts, namely minimal drag.
Ok, he's doing it HO, but there any reason it shouldn't work in G, although I couldn't find any retail kits for larger scales and would be interested if anyone has tried anything similar, in any scale, but especially G.
