Re:Yet to be named railway
Started the platform today. I've made it out of all weather (gypsum) board, 6mm thick. Two layers brings it to just below (0.5mm) rail level. The sheets have a different finish on each side. One side is smooth and the other textured. I've used the textured side uppermost. A coat of mucky green acrylic paint gives it a base colour :'( . Then it's down on bended knee
to scratch the lines for the flagstones.
Scratching completed and a little light distressing to the surface. You can see the textured nature of the surface in the first picture.
Humbrol matt black was thinned using white spirit and then liberally applied over the surface and the colour soaks into the scratches.
A couple of coats of matt varnish add a bit of protection from the weather. A white wooden fence along the back edge to segregate the goods road and a small waiting shelter should help set the scene.
