Chameleonman
So I typed this request into MS Copilot not expecting much. “Create a g scale model railway layout with two loops”. This is what it came up with:
Here’s a practical G‑scale (1:22.5–1:29) model railway layout featuring two continuous loops, suitable for a garden or large indoor space. I’ll keep it flexible so you can adapt it to your available area in Chelmsford.
Concept: Double‑Loop Garden Railway
Overall Idea
Key Features
1. Outer Loop – Main Line
Track Components (Typical)
Scenery & Structures
Expansion Options
Next Steps
If you like, I can:
What space do you have available, and will this be indoors or outdoors?
In about 45 seconds it also rendered the attached image! I just need to figure out how to get it to build it for me!
Overall Idea
- Two independent continuous loops:
- Outer loop: mainline passenger or express running
- Inner loop: freight, shunting, or branch‑line operations
- Crossovers allow trains to move between loops.
- Designed for reliable running with gentle curves and gradients.
- Minimum: 4.5 m × 3 m (15 ft × 10 ft)
- Ideal: 6 m × 4 m (20 ft × 13 ft)
- Track radius assumptions:
- Outer loop: R3 / 1500 mm radius or larger
- Inner loop: R2 / 1200 mm radius
Key Features
- Large-radius curves for smooth running
- Passing station with:
- Platform
- Run‑round loop
- Scenic focus: embankments, bridges, tunnels
- Smaller radius but still G‑scale friendly
- Goods yard with:
- 2–3 sidings
- Small goods shed
- Engine spur
- Optional short gradient (max 2–2.5%)
- Two manual or electric points connecting loops
- Enables:
- Continuous running
- Operational interest
- Multiple trains at once
- Track: LGB or PIKO brass (excellent for UK weather)
- 2 × loop crossovers
- 2–3 × yard points
- Power:
- Track power (analogue or DCC), or
- Battery/RC for outdoor reliability
- UK‑inspired or European alpine theme works well
- Raised beds with:
- Dwarf conifers
- Ground‑cover plants (thyme, sedum)
- Weather‑resistant buildings (resin or treated wood)
Expansion Options
- Add a third elevated branch
- Engine shed with servicing area
- Hidden storage loop
- Live steam‑friendly clearances
Next Steps
If you like, I can:
- Customise this to your exact garden or room size
- Produce a precise track list (LGB or PIKO)
- Create a visual layout image
- Design it specifically for live steam
