My (Currently Unnamed) Garden Layout
biggsy1984
I started my layout about a year ago and thought I'd share my progress. It's an FN3 scale narrow gauge layout shaped in a folded dogbone with a large space in the centre to operate it.
Here is an early plan I drew up, It's located on a slope so the top 1/3 is dug into the side of the hill with the spoil to be used to raise the track further down the slope. I divided the plan into 3 phases.
Firstly the loop on the left side will be constructed with a temporary track to join the tracks forming a circle.
Second is to create the double track line mainline towards the other loop
The third phase will be to create a large raised area for the return loop at the bottom of the picture.
The next few pictures are of the initial construction
Once the initial raised section was built up and compacted down I laid down some track directly onto ballast on a membrane
By Autumn 2025 trains were running in a simple loop with a 15-16' diameter, I should point out that this is a dead track layout with battery operated locomotives. I'll add the next updates in another post
After an extremely wet January and February I noticed that the track had become uneven in a few places so I decided to re-lay all the track onto blocks laid on compacted sand.
Here is the track laid out roughly before the work began
And here it is after building it back up and re-ballasting it.
Next I started building up the centre to create a series of hills for a miniature forest
and here are the trees ready to be planted, a mixture of Alberta Dwarf Spruce and a variety of Dwarf Blue Spruce
Planted
Here's a shot of my Bachmann Climax running on the mainline with the Consolidation in the siding.
And here's a shot of the Climax steaming through the trees in the sunshine
Really nice work on your line's construction. Yes, good track bed preparation is esential. I very much like your choice of motive power. And trees........I learnt the hard way. You know those pretty little bright green ones. I forgot to read the lable when I bought 3. Got round to it 10 years later. It said - Average growth over 10 years.......18 feet ! "That's about right", I thought, as I looked out of my 1st floor bedroom window watching their tops gently sway in a stiff breeze. Things grow, even the dwarf species. Good thing is as at 1.20.3 a 20ft tree scales out at around 400 ft, which is about the height of the tallest Redwoods can attain. They make great features, with whole communities sheltering under them. Max
Thank you for the kind comments.
To answer your question dunnyrail, yes there is a master plan behind the scenes which involves building a much larger layout in the future. At the moment I thought I’d keep it manageable and just get it up and running!
I’d like to eventually incorporate a large bridge/trestle which utilises the slope so that we could walk underneath it to access the bottom of the garden.
And to Maxi Model, I bought these varieties as I’ve read they only grow 3/4 inches per year so I can get away with pruning them once a year - hopefully…
Like you say, the scale of these models would allow them to be 5-6ft tall and still look fairly in keeping.
You do realise, that once you get to a stage where you can actually run trains..... The rate of work on the rest of the line tends to slow down markedly.. :nod:
Oh yes - we've all done that :p:p
Looking at the title of this thread, I'm not sure that the garden needs a name, but hey - it's looking good for a lot of effort.
My track base follows Colonel Stephens principles - keep it light and simple, if it settles, lift and re-lay. The garden's always moving, old tree roots rot away, new tree roots come along - but the trains keep a'moving , on down to San Antone ................ :rock::rock::rock:
when i saw this tiny circle, my first thought was: this would be ideal for building a turntable!
Brilliant thought, let’s build on that.
So the plan would be: three to the east, four to the south, three to the north, and just one to the west side, with a few turnouts leading to the storage shed.
Brilliant start, and thread. I shall look forward to watching this progress over the coming years! Plenty of photographs along the way please....
Work has begun on phase 2 of the line, this picture shows the mainline extension which will run down the side of the fence on the left eventually reaching a return loop.
The centre of this near curve will be fully excavated so the track will be at waist height when finished. The spoil from this will form the return loop which will be located in the background roughly where the wheelbarrow is.
Here's a few more photos, the inner loop is only there to give a general idea of where the track will go, the angle is slightly off in the photos.
Thanks for looking.
Thanks for looking.
Thanks for sharing.
I don't know about others on the forum, but I do love seeing a railway develop from the ground up. I anticipate, yours is going to be particularly scenic.
Thanks for the tips on dwarf conifers, BTW.
Rik
This endless hot weather we're currently experiencing in the south east of England has almost entirely halted any progress. I've managed to ballast a small section of the mainline extension and excavate a bit more of the upper section to start building up the second loop.
The main problem has been the new plants which only went in this spring and have suffered enormously from this extended dry spell. When I planted them I didn't think to add a membrane or to add mulch so they required watering almost every other day and even this wasn't enough! After a few started dying out I decided to dig them all up and re-pot them with enough compost and mulch that they would look after themselves with minimal watering.
I then added a membrane and a 3 inch thick layer of bark to the central area with a view to replant them all in September.
I'm currently propagating about 250 Boxleaf Honeysuckle cuttings to cover the wall at the front of the last picture.
You have done the right thing. About 7 or 8 years ago we had a very dry and hot summer. It took out one or two well- established slow growing "prostrate" type conifers as well as some planted early spring. This despite a good watering regime. I wish I had had your foresight then with regards to repotting the new ones. Problem is will these long dry summers now become the norm. Don't bet against it, are we going to have to rethink the planting of our gardens ?
