All,
Have just fitted XLS decoders to two Forney loco's.. Identical (or should be!).
One is fine, the other has a strange effect on a Massoth CS. - It is fine on my Digitrax unit.
The motor, and light, functions are fine. Sounds when running are OK. It is only when the effects (whistle etc.) are triggered by pressing function keys the 'fault' occurs. - As I say, these work fine on my Digitrax CS.
If you press F1 (say) for the whistle, you get the whistle effect triggered multiple times.. This does not seem to stop unless you hit the F1 key again. Same for the other effects, so all are doing the same thing, but only with the Massoth CS.
Any ideas?
I only have the 'faulty' loco to play with, and not local access to a Massoth CS. I can supply CV values if asked.
TIA,
Any ideas?
TIA,
