Ralphmp
I’ve just installed a second Massoth Auto Uncoupler, connecting it to the A02 terminal on an XLS decoder. The first one is attached to A01 output and works as expected using key F7 on the Navigator. However, I cannot get the second one to work at all. (I’ve checked the installation to make sure there are no mechanical issues and all seems OK.)
The default XLS settings have A01 activated via F7 - which worked “out of the box” - but the default for A02 appears to be activate via F2. However, F2 also sounds the bell and when pressed on the Navigator that’s all it does; there’s no action with the attached uncoupler. I therefore selected a different F key - F5 - via the Massoth Service Tool having first disassociated the F key from any other action. The MST reported a successful allocation of F5 but when pressing this on the Navigator still no response from the uncoupler.
Whilst I have several years’ experience of using the MST to tune my decoders this is the first time I’ve tried adjusting F keys that activate auxiliary outputs. i couldn’t see anything particularly relevant in the XLS config manual, so I’m thinking either there is some setting I need to adjust, or the uncoupler itself is fault, or maybe the A02 part of the XLS itself is at fault.
Any suggestions would be appreciated.
Thanks
Thanks
