Trainline45 R2 points
Oops forgot to post re the fix of the Bump at the Frog. I fit a thin piece if 20thou Plasticard in the Gap either side of the Frog. This is glued in with Uhu or some suchlike Glue. This allows the Flange to ride at perfect Rail Height stopping the orrible Bump at the Frog as the wheel would dip into the Gap.
I also have in some cases filed a small bit off the Edge of tge Frog at the Tip of the Vee. This also helps with smooth running.
Ralphmp said:
Gizzy - Out of curiosity, did you use the DCC address the TL motor came with or did you reprogramme it (and if so, what did you use to update the address CV)?
I reprogrammed it to address #4 using my MTS Universal Remote I think? I may also have tried to read it using the 55045 Interface....
