After the many helpful suggestions I’ve taken stock and realised that before deciding on which way to go I needed to understand what I really want from this exercise.
To date I have controlled points via DCC so I have been used to having everything operable from a single “location“ - my Na vigator. However, I didn’t plan for this it just happened as a result of using DCC. And whilst it may be convenient, there are downsides - by not being at the points when they are switched you are neither 100% sure they have been switched to the correct route nor that there isn’t a little bit of something trapped in between the point blades. Just because you hear a “clack” from the EPL motor doesn’t mean everything is ok.
So, Question 1 - do I want/need all my points operable from a single location? On reflection, no I don’t want this (and I’m still mobile enough to not need it).
Question 2 - do I want/need some kind of “arm’s length” manual operation for my points; e.g. rodding, cabling? Given my layout, this isn’t essential for all but 2 sets of points, and these will be replaced in the next phase of layout rationalisation. I‘m also not that handy when it comes to making mechanical things, so I think trying to replicate the mechanisms used successfully by other folk is likely to be beyond me.
I’ve therefore decided that what will most probably work best for me is to operate my points at their location using a lever attached to them. Which leads to the Question 3 - which type of operating lever? My criteria for the ideal lever for me are -
must have the correct throw for LGB points without the need for any fettling
must have a design that “locks” the point to the chosen route
must be sufficiently robust that it will stand up to being used by a cack-handed oaf like me
must make it obvious by its position which route is selected
must look reasonably realistic (bit subjective)
ideally, can be used without the need for painting, treating, etc.
So thanks again for all the suggestions- I‘m now going to do some research against my criteria and maybe try on or two options out.
If there is any interest I’ll report back on how I get on.
