Simple Shuttle "lash up"...?
CoggesRailway
8
Hi All,
I am now realising my leg injury is not going to allow me to lay the patio, which needs to be down before I can complete my loop - (which was truncated by extension works) any time soon.
However I would like to run trains. Is there a simple (well cheap) way to set up a loco going backwards and forwards for watching pleasure? I am not worried about the actual stop revesere looking good and don't want to spend much as it will only be in use till spring when I should be fit enough to re join the loop.
Ian
Neil Robinson
579
N W Leicestershire
Hi Ian
Are any of your locos chipped?
Do you want a delay or an immediate reverse at each end?
whatlep
1
Worcestershire
www.facebook.com
CoggesRailway said:
(snip) Is there a simple (well cheap) way to set up a loco going backwards and forwards for watching pleasure? I am not worried about the actual stop revesere looking good and don't want to spend much as it will only be in use till spring
Hi Ian
Simplest thing is probably to buy either from EBay at GBP40.00 (buy it now option) http://cgi.ebay.co.uk/LGB-8-Amp-Shu...=UK_Trains_Railway_Models&hash=item4aa6dca560
or get a Gaugemaster SS-1 shuttle unit for GBP39.95. http://www.gaugemaster.com/ < Link To www.gaugemaster.com or instructions here: http://www.gaugemaster.com/instructions/ss1.pdf
The EBay one has a higher stated amperage tolerance, so may be more suitable for your beefy Alco! :clap:
Offer to help lay a temporary loop still holds good, by the way.
yb281
7
Worcestershire
www.facebook.com
Same here Ian, if a working party is required just ask - it's been done before. You just have to be able to afford the cake! :clap:
mmts
62
Essex and you dont need your passport
What's that you say..... There may be a works party required over Xmas????? May be interested in lending a hand....
Gizzy
36,148
2,278
63
Cambridgeshire
I've got an LGB shuttle that I could loan you until you are back up and 'running' Ian?
PM me....
CoggesRailway
8
Thanks very much chaps! PM on the way Giz... As for the working party sounds fun. However the area it needs to cross is a complete building site, and needs to be "patioed". I will keep it mind, and one things for sure when I get through this and recommission Cogges railway one way or another you will all be invited!!!
Gizzy
36,148
2,278
63
Cambridgeshire
PM replied to!
Help is on the way....
