Points and signal r/c from Deltang
ge_rik
1,244
Cheshire
www.riksrailway.blogspot.com
Just noticed on the Deltang website that David is working on a points and signals remote control. The first off the production line appears to be one which will control up to seven points/signals - http://deltang.co.uk/tx27a.htm
Looking at the description for the receiver/controller, it looks as if it can be configured to control semaphore signals (with built-in 'bounce' at the end of travel) or points or lights in various combinations. http://deltang.co.uk/rx105-110.htm
It also looks as if he's also working on a controller for 20-40 signals / points.
I think David must have been reading my mind (or doing some clever market research). I've been thinking about how I will control some of my more inaccessible points when I eventually abandon DCC in favour of battery power. And I've been considering using servos to control my semaphore signals.
I think my post-Christmas birthday wish-list has suddenly been filled!
Rik
bobg
3 May 2010
20,141
25
Middle Earth
Haa! Velly intellesting!
Bram
Playing trains, Ballroom Dancing, Good Food & Wine
4
Knowle
It has possibilities
gregh
1 Nov 2009
3,137
263
Sydney, Australia
www.members.optusnet.com.au
Sounds like a good idea. One of my friends uses RC for points and just puts a LiPo battery at each 'interlocking' . So he doesn't need a power supply for the RX or the turnouts. Takes the battery inside when finished running and charges it.
nicebutdim
14 Dec 2009
4,694
16
Sunny Surrey (Ha)
I've had all my points under rc control for quite some time now. Quite easy and cheap to do. Signal bounce is out of my scope though.
tramcar trev
22 Jan 2011
11,577
8
Canberra, Australia
trevs-tramway.blogspot.com
Looks like a good idea. I reckon that as GregH says (and based on my experience with repackaging a commercial R/C unit) it would be very simple to do as he has done and go DIY. Signal bounce would be a function of the servo that throws the points and signals I would think, take it overcentre with a very light spring to cause the bounce....
Unfortunately all my points are automatic except for 2 and they are thrown by use of a point hook....
gregh
1 Nov 2009
3,137
263
Sydney, Australia
tramcar trev said:
.........Signal bounce would be a function of the servo that throws the points and signals I would think, take it overcentre with a very light spring to cause the bounce....
Easy enough to do bounce if you're using a Picaxe to drive the servos.
tramcar trev
22 Jan 2011
11,577
8
Canberra, Australia
Or have a trained elephant stamp its foot in the vicinity.....
3,526
Do you need a trunk circuit to control the elephants?
OR
Do you have to poke the elephant with the picaxe to get a response?
Hat, coat, door..
