Valkea said:
Hi.
Checked track with volt metor and it is a cre-5480 basic train engineer control system. Thank you Ken.
That set uses PWM (Pulsed Width Modulation), so if you use a meter set to DC Volts, you will have about 14 Volts on the rails all the time. PWM basically works by feeding a short pulse of power to the motor, i.e. change the frequency. Think of it in radio terms as FM rather than AM as a conventional Controller which varies the voltage.
I would try using a standard controller from an ordinary OO/HO set if you have one to check that the loco is working, as I expect it will.
Other things to check please;
Is the aerial properly connected?
Are you sure the new batteries are okay? Rechargeables are often 1.2V and this might not be enough to operate the set. Make sure they are 1.5V. Check the battery terminals are clean with no corrosion.
Is there an indicator LED on the handset that lights up when you operate the controls. (I have owned a TE a couple of years ago, but it was the black version and not the orange one that you have.)
Sorry if these are obvious questions, but I need to make sure the simple things have been looked at first....
