Voltage and amps act differently.
Once connected, the voltage is sort of everywhere, like used or not, every socket in your house is 220 volts.... even with nothing plugged in.
Amps are a measure of what is flowing, and if there is nothing flowing, there are no amps, again like your house, the amps only flow depending on what is plugged in, a light bulb is less than a teapot.
So to your switchbox, 24 volts ok, no problem... amps? the contacts are rated on current each...
What do you intend to hook up to the switch boxes, and most importantly, how many amps EACH do they draw?
