LGB 50610 Girder Bridge
funandtrains
20 Sep 2011
3,833
35
55
Croydon, Surrey
Please can someone tell me the clearance width and height of the large LGB girder bridge?
lgbmad
Model trains....G scale mainly, but enjoy all othe
20 Oct 2011
1,146
47
Llanfyllin,Powys
Hi there......width 16cm and height 22cm....hope that helps.
Kev
phils2um
Phil S
11 Sep 2015
1,522
423
Ann Arbor, Michigan
United-States
Sounds about right. Just don't run with pantographs up unless you've put in a short stretch of catenary! Speaking from experience!
Phil S.
funandtrains
20 Sep 2011
3,833
35
55
Croydon, Surrey
Kev
Thanks, great 16cm width will clear most stuff even the big 1:20.3 scale models although a bit tight!
3,524
If you can arrange your track to have straight sections, either end of the bridge, it helps a great deal with long or overhanging stock..
funandtrains
20 Sep 2011
3,833
35
55
Croydon, Surrey
Phil S.
Thanks, luckily I don't own any pantograph locos.
funandtrains
20 Sep 2011
3,833
35
55
Croydon, Surrey
I will try to to do that, a good point I had forgotten about as the long coaches cut quite a few corners and the big locos overhang quite a bit at the ends.
maxi-model
661
Bucks/Oxon/Northants area
I could get my Bachmann K-27 through even with a slight curve on the approach. The Accucraft K-28 needed the awnings over the cab windows folded in and a straight approach though. No problem with the body clearances and stove pipes on the Accy' J&S combine and Bachmann long caboose. In the end though I replaced with an MVL under beam bridge. Lot more room and made to measure. Max
