Turntable
Livia
Working on a 3d printed modular turntable and currently in the prototype stages
The primary constraint was that the railhead should sit at the same height as standard LGB rail for temporary setups so its not motorized currently.
Its currently sized for a 300mm bridge and 41mm exits. (couldn't be bothered to cut track at this stage of prototyping.) but the whole thing is built using a parametric python script so its easily resizable to any bridge length.
The script also generates the PCB as a Gerber for a slip ring to conduct power to the bridge rails.
Exits are position-able to any one of 14 spaces around the ring to roughly (ish - its out by 8-10mm give or take) bring tracks to R1 parallel spacing where an R1 curve is used. Blanking modules where no exit track needed.
The bridge aligns to exits using a ball detent at either end.
The bridge will run on a 6mm steel dowel in the center and 4 bearings, 2 at each end of bridge (see slots at bridge ends.
Waiting on hardware from Aliexpress to complete and if all is good mechanically then i'll reprint in PETG and order the PCBs for the slip ring.
