Dietz tail lamp..?
Phil
Trains, Just Trains.
24
28
Oldham, Manchester.
Hello
I've seen these on some videos on youtube but can't find any information about them on the web?
Anybody got something?
[*]Price?[*]Sizes?[*]Voltage usage? Cheers Phil ;)
nicebutdim
14 Dec 2009
4,694
16
Sunny Surrey (Ha)
I've seen them before, look very good. No idea about the specs though, but I made my own with a 1x1 white (or yellow) Lego brick ( http://www.ebay.co.uk/itm/LEGO-WHIT...UK_Construction_Toys_Kits&hash=item43a9ee0b58 < Link To http://www.ebay.co.uk/itm...mp;hash=item43a9ee0b58 ) with the top filed down, a 3mm red flashing led and a small battery box. Cheap, effective and looks just fine. I will add a pic shortly.
They work quite well on top of end of line buffers too.
Gizzy
36,165
2,282
63
Cambridgeshire
images
images
That's a clever idea Tim!
Phil have you tried googling Dietz and finding their website? Might be a reference to a UK supplier for these lamps....
Phil
24
28
Oldham, Manchester.
Just Dropped Glendale Junction an email, seeing as they stock some dietz products.
Phil
24
28
Oldham, Manchester.
Anybody got an idea of the best place to attach it to the wagon?
Phil
24
28
Oldham, Manchester.
Nodrog1826
Professional Idiot
21 Nov 2013
9,005
2,735
United Kingdom
Ok Phil and anyone else who may find this useful
First the cost, 29.00 euros from Grootspoor, that's where i got mine from, as part of a larger order....
It comes with instructions, in various languages but not English, and they do not produce them in English, but i found Dietz helpful in providing info by Email,
as i had a concern over voltage and blowing the diode. Which turned out not to be a problem.
Sizes
Circuit approx -- W 15mm L 40mm H 10mm, excluding the diode wires approx 25mm and 450mm tails.
Lamp approx - - W 10mm (at widest point (it tapers)) H 15mm (over loop handle) D 8mm.
The diode has a square end with a ctr pip for the want of a better way to discribe it, that is a loose fit into the recess on the back of the lamp itself.
In fitting it to the coach you need to dril a 7mm hole in the coach wall for the diode head to pass through to the lamp, or i guess you could cut the diode free and solder extensions to it on other vehicles,
i guess it is a soldered connection to the circuit board, but i did not remove the thick shrink wrap to see.
Lamp itself is a hard brass or alloy painted (I think its actually an overlay of some sort on the front) as in the photo with the rest of it grey, i drilled and tapped the rear of mine so i could fix it to the coach, rather than glue the diode to the lamp as the instructions state, thats how i found out it was hard.
It will work on both DC and DCC.
Whilst on DC it is not polarity dependant, it takes longer for the capacitor to charge on reverse polarity. DCC is a allmost instant start up.
On both you get a gradual build up in the intensity and rate of the flash until it settles at the rate in the vid link above.
Should add because of the capacitor in the circuit, it will continue to flash for some time after power is switched off, approx 10-15 mins in my case,
i did fit a switch to the underside of the coach so that it can be isolated.
The cast iron test as far as i am concerned, would i buy another one........Yes..
