Cheap Wagon
P
792
55
considering, that playmobil uses the truck mounted couplers to keep the wheels in line, i want to ask, if you could make a pic from the underside.
i'm just curious, what, if anything, they did to line up the wheels after putting body mounted couplers
Korn, sorry I missed this post, here's some pics of it's under pinnings
D
Dan
28 Jan 2010
170
18
Eastern MA
#23
The knuckle coupler is a KADEE and will mate with the LGB knuckle just fine. I run the LGB FRR cars with the Kadee couplers on a 29 inch circle. That is 737 mm.
Riograndad
Riograndad
6 Jul 2013
1,447
498
64
Northampton UK
#24
Bargain,great bash fodder!
korm kormsen
korm kormsen
253
#25
thank you, Paul.
interesting - there seems absolutely no measure been taken to keep the wheels aligned.
Playmofire,
the lead-weights are not necessary imho.
all my playmobil cars run without weights since the mid-eighties - without problems.
but the wheights are great to hold down coffee stirrers, while the glue dries.
P
792
55
thank you, Paul.
Playmofire,
There is a stop which prevents the wheels turning too far, and it looks like something has been cut from the moving bit as well, probably something to do with the couplings being removed
P
playmofire
23 Oct 2010
6,382
692
North Yorks
#27
The coupling loop and the "neck" it is part if have been cut off. In the attached photo, the yellow circle shows where there is a small moulded hook (one either side) which limits the movement of the wheels.
18:10 edit to correct mistypes resulting from correcting an earlier mistype.
