I have had a Mallet come back to me..
One motor was a little poorly, so both were replaced. The idlers do not appear to be worn, but the loco is 'jerky'..
Seems to be the rear motor-block / bogie assembly.
I know you will all say 'quartering', but it appears good. - I have moved a tooth either way, at both ends, but it has not improved it.
Motor-block pulls less than an amp, at any speed I run it on rollers. Presently have 8 x AA's strapped to it, and running it round the garden.
This model has press-on wheels, and this block has the reeds (for track magnets) and a chuff sensor axle.. The only thing I have not done is remove the 'chuff' axle to check the wheels have been pressed back on 'in quarter'. - I believe this to be OEM, but could be wrong?
Any other ideas?
Thanks,
Any other ideas?
Thanks,
