Dodod driver
I bought one of these new in the late 1980s. It hasn't had a lot of running over the years, but I notice that the bodywork beneath the rear of the loco gets very hot. This occurs on both dc and dcc operation.
Drawings of this loco from the internet dated 1999 show the motor to be located under the cab floor, with a worm on the motor shaft driving a gear on the rear axle. However, the leaflet with the loco refers to a gear box needing lubrication. This isn't shown on the 1999 drawings.
The motor appears to be getting hot as I can't see any route for cooling air to circulate around it. It sits within a sealed box of the loco frames at the sides, the cab floor above and another section of bodywork underneath.
Has anyone else experienced this problem? Is there a solution?
Thank you very much for any suggestions.
