Ok, kit of parts made up
long flat bars 12 x 2 mm are the MOUNTING BARS, the two 4mm holes close together are for mounting under the bogie with no lateral give , so that wagons can be pushed with NO zig zag that could cause derailments
The hollow square sections are the POCKETS to hold the links, so that they can SLIDE
the 45degree cut away allows the face plates to meet without the links getting trapped between the faces
The short bits of angle are mounted above the pockets for a BUFFING surface when pushing wagons
The 3 loop links are designed so as to allow wagons to swivel vertically in relation to each other, & without applying any forces that would cause derailment
while BOTH pushing or while pulling
