I am awfully confused. I have also discovered that toggling F7 on the navigator does not affect whether there is power to the smoke unit. I am certain that the "pip" sound is load sensitive in so far as it only occures when accelerating from one speed to a higher speed, otherwise there is no noise. When I purchased the loco I had the sound card fitted before I took delivery so have no knowlege of the performance of the smoke unit and surmise that it was always powered from the original control card, but now it is wired through the sound card. Would it be worth replacing the power wires from the smoke unit back onto the main card and on what output do I wire it to?
NO!
Chas, the pulsed smoke unit has a chip in it (it is its' own decoder) so it has track-power all the time..
F7 (if it is configured that way..) sends a command to the decoder in the smoke unit to turn it off/on.
The track-power wires (may) go into the track-power connections on the sound decoder, but this is only a way to connect everything together.
The sound decoder (and smoke-unit) are probably connected by a thin, 3-wire cable?? - This is from the pulse trigger to syncronise smoke and sound to wheel rotation.
