0-3 switch in a stater engine --- remind me.
Sean.
Hmmmm
5 Oct 2017
2,995
1,086
66
Boston & Cocagne NB (not enough)
OK I have this engine.
th
The switch in side goes 0-3 .
Can you remind me what each # is for ?
Does this have a smoke unit?
Thanks
Sean
Gizzy
36,141
2,273
63
Cambridgeshire
Need the LGB number to be certain Sean....
Zerogee
Clencher's Bogleman
1,723
North Essex
I think that the cab switches actually only have three positions, not four - standard LGB manual indicate 0 = all power off, 1 = Lights and smoke on, motor off, 2 = everything on. Position (1) is for parking a loco on an unisolated track section (when using DC).
When using DCC, the switch is out of circuit and doesn't do anything.
Sean.
Hmmmm
5 Oct 2017
2,995
1,086
66
Thank You ..just what I thought/tried to remembered..
Madman
2,958
Pennsylvania, USA
What the hey ! Throw the switch and see what happens.....:mad:
Neil Robinson
579
N W Leicestershire
Some have three positions but others have four. The fourth position (numbered 3) is for sound on/off. This might be present but ineffective if the mould is used for both silent and factory sound fitted examples.
Dan
28 Jan 2010
656
52
Eastern MA, USA
I find that position 0 is all off in the LGB DC powered engines, position 1 may leave the lights on and highest number is usually everything on.
BakerJohn
Baker, Modeler, Flour Ambassador
3 Feb 2018
650
218
28
West Warwick, RI
leedshillrailroad.weebly.com
Before I rewired #10 the loco had a four position switch in the cab.
0- all off
1- lights & smoke
2- lights, smoke, motor
3- lights, smoke, motor, & sound (which i would have had to install myself)
Zerogee
Clencher's Bogleman
1,723
North Essex
0- all off
1- lights & smoke
That all makes perfect sense, because if you have an analogue DC sound loco there needs to be a way of running it with the sound off after the neighbours have gone to bed!
