Weathering a loco with Matt varnish
pugwash said:
It's a really strange sensation having all the hairs on your arm stuck together!
Obviously spray up, down and side-to-side to get an even coating and not just from one level. :thumbup:
8| Best way if you want to cover all your arm! :laugh:
Richie said:
Zman said:
The title of this thread struck me a something to be found on one of the documentary channels,
"Hi, I'm Matt Varnish, and this week I'll be ....." :laugh:
Sounds like the Fast Show
This week i'll be mostly getting dirty :laugh:
This week I'll be mostly be wearing matt :bigsmile: .....sorry Matt
Then go the whole hog and spray yer armpits for a laugh :rolf: until you realise you can't pick up your beer glass :impatient:
ROSS said:
Richie said:
Well i took my Bachmann Porter apart today and weathered it not gone to bad wasn't as easy as the log wagons just need to fix the powders with help from Matt Varnish but need the wind to drop so i can spray . Will post some pics soon .
Like to see those Rich.. I have two LGB Porter 0-4-0's to do.
Some nice pics of "bashed" Porters on the 7/8th scale forum.
Hi Ross
Just sprayed loco with a little help from Matt Varnish . Got loco back togeather and doesn't look to bad i'm happy with the result just need to add a little bit of rust onto the loco's wheels . On the windows i cut the tape so that it left the rims of the glass and frame to get weathered . Put real coal in the bunker and floor round fire box . Driver just needs a little weathering now .
Heres a few pics for you
Absolutely ace :thumbup:
Looks really good - like the cab "scene" very much also.
Mick
Just give him a few bucks to go out on the town on a friday night, that should do the trick (bleary eyed, unshaven, thick'ead). :bleh:
And before Zmate pokes his oar in, yes, and not just fridays :rolf:
Richie said:
Just sprayed loco with a little help from Matt Varnish.
8| You and Matt have been busy ;) :thumbup:
A lovely spot of weathering, I do like em dirty! I've got a load of weathering to do if your not too busy Richie!
steam locos look so muh better when they look like they earn their keep.
Nice, mind you despite what I said earlier about overdoing it, this is what happens at Barry when you leave em outside in da salt air.
Is there no chemical reaction between saline solution in suspension and brass?
Or do you have loads of Brasso? :rolf:
Here we go, open the floodgates to all the 'brassed off' jokes :bigsmile:
WELL DONE MATE...i like it.....loves it and u will get the hang of it from weathering!!!.....loves tht good idea for the inside cab with real coal....kool........
Very prurty, very prurty. Nicely done again Rod
Good job Richie. Got the appearance that she has been about a bit hasn't she? Looks a wee bit saddle sore..........saddle loco.... gedit......oh well please yourself
:bigsmile:
Matt Varnish would just like to thank all you chaps for all the kind words and comments :clap:
Look out for his new show coming soon Weathering a flat car :laugh:
Hi Rod
What a wonderful job looks fantastic was this done with powders ?? How did you weather your wheels and valve gear as i taped mine up to stop the varnish getting to the electrics ??
Cheers Dave , Sorry just a bit busy have a 1001 jobs to do none of which are train related :crying:
Woderwick said:
Thanks Mike, but puggy is right again
Hey? What? Pleeeeeeeaaaase send that in writing to my wife, pretty please? :bigsmile:
Hi Rod
I only masked off the wheel tyres, the rest?
Paint and powders sir. First he paint was diluted to a thin wash and applied with successive application to give the appearance of a build up of textured grime. One single application does not seem to convey the same effect. The eye is a wonderful thing and can detect even the smallest nuances in colour and texture so I try and do a little at a time. It is always a hard call to say when to stop.
I often let the wash run down the side of the loco. You can see this to good effect under the blower pipe here. Note the bent and grubby lamp with shiny handle from use. The crew has hung it in a convenient place for ease of use. Not sure what the story with the hammer is though. Something is missing from the smoke box at the front. I wonder what it was and where it went.
The top view shows some of the powder application. The smoke box and door has burned because someone did not secure the door properly, maybe a piece of crud got wedged in the bottom when it was last cleaned. As a result of the paint going west, some corrosion is starting to make itself evident.
Particles of ash litter the pilot and step from careless cleaning. Clutter litters the top of the tanks, at least the fire irons have been stored in the correct place. Again the handle on the tank hatches has a slight shine from use, where as the two lamps in contrast to the one at the front clearly have not be touched for ages, as witnessed by the dull handles.
The loco is usually left outside with the back parked towards the prevailing (salty) wind and so is filthy at the rear. You can see that the late afternoon sun exacerbates the redness of the washes. Just in front of the cab window the tank filler overflow has got in to the weld seam and window frames. The chain on the back has been hanging there for ages and has started to wear and stain the paint. Again, the grab rails and cut bar handles are shiny from use in contrast to the surrounding neglect. The herald and number have been wiped down with an oil rag however and that's about it. If you look close you can actually see a circular smear around the number.
Twas fun
