In my last Post on my New Line Thread I mentioned that there had been two purchases at Glendale. Well the other one was this:-
A Trainline 45 Curved Right Hand Point. I had for some time been thinking about converting another one of the Dead End Roads in my Stiege Low Level Fiddle Yard to a Through Road. Operators had been having problems with Running Round in spite of the assisting Pilot. The Track Situation was R2 Curve, LGB Short Straight then another R2 Curve followed by Straight. It is the Track at the end of the Road 2nd from Left. Sorry test fit slightly obscures Rail Situation.
One very interesting feature of the New Trainline Curved Points is the Reed Switch together with a Small Rare Earth Magnet for Frog Polarity Juice Changing. Very effective and ingenious. Not sure how well it would last outside, but inside it will be perfect. Just remember it is there though when pining down the Rail. I do not pin the Track Down in the Fiddle Yard relying on the Small Blocks of Timber between the Rails that you can see in the Pics to keep things in place here.
I wonder if the rest of the Trainline Range of Points now have this Modification?
I had decided that an R1 would and could not be used in this location in spite of this being the obvious solution. I had a RH Train Line R2 in stock, but this did not fit in the location. So I cut up a piece of Wallpaper Backing Paper, traced out the relevant Track Layout and asked those nice people at Glendale when I got there if I could open up a Trainline Curved Right Hand Point to see if it would fit. It did just so a purchase was made. A quick removal of the existing Track and cut up of varying Short Pieces of Rail including butchering the R2 Curve into 4 yes 4 bits and it all fitted nicely. For convenience I used the Air Line to the Point where the Coaches are Standing. No need to worry about that being Shunted at the same time as it is just a Storage Road. Never gets used in the TT.
One slight niggle with both Trainline and LGB is an irritating Short on the Rails just before the Frog. I have used some Insulating Tape to resolve this as can be seen on the Last 2 Pics. The second Pics is the LGB Point that has had this fix for some time. As you can see the Tape has lifted a bit but still functions perfectly.
