Train jittering .
Another stupid question....
I wish to add the Powercap 900
looking at how to do this below Im concerned I may make mistake on the Cv29 etc.
Would you recommend sending my little loco to have it fitted by a greater mind than mine?
Im good at model detailing... bad at electronics... x
Thanks Chris
AI Mode conversation: DECODER 8154001 Massoth eMotion L 2.5A how to connect to powercap​
To connect a Massoth eMOTION Powercap (such as the Powercap micro or Powercap 900) to a Massoth eMOTION L (2.5A / Article No. 8154001) decoder, you need to connect three wires: power, ground, and a digital control line.
Using the Buffer Control (BC) feature allows the decoder to automatically switch off the power cap during programming so you do not have to install a physical isolation switch.
Step 1: Wire the Connections
The Powercap features a 3-wire cable harness that must be soldered directly to the appropriate contacts on the decoder:
  1. Red Wire (Decoder +): Solder this to the Dec+ common positive pad on the decoder.
  2. Black Wire (Decoder - / GND): Solder this to the Dec- (Ground) pad on the decoder.
  3. White Wire (Buffer Control): Solder this directly to the function output pad A5 on the underside of the eMOTION L decoder.
Note: Ensure your soldering iron does not bridges adjacent pads, as short circuits can permanently destroy the electronics.
Step 2: Configure the Decoder CVs
Once wired, you must program the decoder using your DCC system to activate the Buffer Control feature and protect the circuitry during programming.
  • Activate Buffer Control (BC): Set CV 118 = 31. This assigns the A5 output to handle the automatic smart charging and deactivation loop.
  • Disable Analog Operation: Set CV 29, bit 2 = 0 (e.g., if CV 29 is currently 6, change it to 2).
⚠️ Important: You must disable analog mode in CV 29. If analog operation is left enabled, the decoder will misinterpret the stored energy from the Powercap as an analog track voltage supply when DCC power is cut, causing the locomotive to run away uncontrollably.
Programming Safeguard
With CV 118 = 31, the decoder automatically cuts off the buffer line whenever it receives programming commands. If you ever need to reprogram the decoder and find that it fails to read or write properly, you may need to physically disconnect the white wire temporarily to ensure the capacitor isn't absorbing the programming signals.
Hm may be a good plan, I put one in a Stainz chassis conversion and all it did was to run the LGB sound box. Loco would not move at all! Clearly I did something wring but followed the where to wire it in as described in the notes.
Just remember, if you're using capacitors, they can hold their charge for quite some time, so make sure they're fully discharged before you start playing around with them! Some of the very big capacitor units we found at work took several minutes to disharge.
Here is an explanation of the difference between a battery and a capacitor:
Both a battery and a capacitor store electrical energy, but they store and release it differently.
Battery⚡ Capacitor
Stores energyChemicallyAs an electric charge
Energy capacityUsually largeUsually small
ChargingRelatively slowVery fast
DischargingCan supply power for a long timeUsually discharges quickly
LifetimeLimited charge cyclesCan be charged many thousands/millions of times
ExamplePhone, flashlight, electric carCamera flash, electronics, small motors
A simple analogy: a battery is like a large water tank—it holds a lot and can supply it gradually. A capacitor is like a small bucket—it holds much less, but you can fill and empty it very quickly.
For example, a small solar-powered toy can use a capacitor: the solar panel charges the capacitor, and then the capacitor releases that energy to run the motor.
Battery⚡ Capacitor
This is a great way to understand…..
We are making good progress on the MTS x
You might also want to have a quick read of this thread...
Hello folks,
hope you are all well and the great sunshine had you all out on your railways.
So we are getting on... 3:10 to Yuma station is built and outside. It looks great with the water tower and wildwest windmill.
Next question is I need to find some wild west isg looking station lamps. Can be wall mounted or on chains.... Ive looked a fair bit online so far no luck. Any tips?
Obv 1:12 dolls works too but industrial looking.
I may have to make them.
Thanks, hows your set ups doing ?
Warm regards
Chris
Hello lovely folk,
been a while. The railraod wild west is coming on.
So I need to buiod a hinge brideg x2 ive been looking at male female conectors which loctae the track and make the power supply.
So which is the best please? Oh I am in the garden for this lovely.
Also it metioned making the track to the opening dead when open. Is this easy is it worth it.
How your summers gone out on your tracks mine is yet to run. x
Thanks
Chris
Hi
also, I am having printed a new rear light and bracket which looks great, this is for my "goat" switch engine.
may I ask if any of you have a snow plough and do they work?
If so which would you suggest.
I can scratch build well so I can fix it to an open wagon to add weights.
Really open to ideas ... and its getting colder. x
Oh and I am on DCC but what are the thoughts on battery? I have 2x decoders do these get used in battery world?
also my garden is a loop and me and the girl like to leave it running of an evening so when we pop in the kitchen it may be passing ... its lit and I decorate for occasiosn.
So given thsi would a battery be better?
Would it last 6x hours ish.
Does thsi make decoders dead?
At thsi early start but x2 decoders and fitted , would it make sense.
we want to control the trains from inside in the winter, and be able to switch it off on the way to bed or indeed set a digital timer... if that possibale.
STL traons have been so so lovely look them up.
Fingers crossed its looking to print a `g scale covered wagon.
x Hope you are all well.
Topher x
Hi
Topher x
Both Fosworks (uk based) and Crest (us based) plus others in USA do systems for DCC using battery transmitters and receivers. Look in the battery thread where you will find threads by me in both these systems.
1 DO NOT CHANGE YOUR FISHPLATE CONNECTIONS INTO TRACKCLAMPS YET!
I learned that cleaning the fishplates and the railtrack ends using a fine steel brush and put some Copper Grease on it provides the best connectivity for many years.
The copper grease is called Molycote (see photo) and is used in the electricity industry. It can withstand strong rains and the sun heat in the summer (withstands even extreme high temperatures up to 300 degrees!)
2 CHECK THE CONNECTIVITY OF ALL PARTS OF YOUR POINTS
Especially when running small (short) locs there can be a connectivity problem when passing the points. So let your Steinz run over each point and watch precise when it stops.
Mark the position of the pick-ups and identify the bad connected rail parts of each point. Again also here use the Copper Grease on the moving electriccity connecting bolts and parts.
3 WHEN THERE IS STILL A PROBLEM WITH THE REST OF THE TRACK USE A CLEANING PAD.
When your track is on the ground the best way is to mount your cleaning pad on a wooden flat plate mounted under 45 degrees at the end of a stick . This enables you to easy walk around while cleaning.
Instead of the LGB pad you also can use very fine sandpaper like P400. It is for sale in square shape mounted on a layer of soft material.
4 A MORE RIGOUROUS SOLUTION FOR BETTER TRACK CONNECTIVITY USING A STEINZ LOC
Put steel wheels with ball bearing electric connectors on all the wagons of your Steinz loc. Bring the feeding wires into the wagon and make a long lectric conductor against the interior roof. (see photo) This enables the placing of LED lamps in the wagons but moreover it enables the connection between all wagons to the loc. Now there are a multiple of connections to the track and your loc will run for ever smoothly.
I still mostly run track-power DCC, but a few years ago I converted a couple of LGB locos to battery power so that I had something to run when visiting dead-rail lines - because I still wanted to retain full DCC control over the running and sounds, I used the Tam Valley DRS system from the US, plus a Stanton Radio Cab (also US made) as a controller - this system is now obsolescent, sadly (I think Tam Valley Depot will still supply the receivers, but Neil Stanton is now at least semi-retired) but as JonD and others have said, similar systems are available from Crest, Fosworks and others. Both the locos I converted are still running very well, and I regularly take them out "visiting" to local running days.
In both cases, I added switches suitably wired to allow me to run the locos on EITHER their onboard batteries or on track power (DC or DCC) at the flick of a switch, so they can pretty much be run anywhere, on live or dead track.
A lot of the principles I used for the conversions will still be applicable whatever make of control system you are using, so you may well find something useful in these two old threads of mine:
Hi,
minus 1 here in Cheshire so log stove on at last.
So I changed my mind on hinging the two bridges on my outside track.
So I am hoping to find male female connections which I can wire to the remaining track so I just pull out the bridge ,to set to one side.
I bought the hinges, but now I see a locked up right angle of the bridge would be a pain in the garden..... so I maybe wrong, but I think a pull out is better.
So does anyone know a good source for male female upright connections for outside.
I have learnt that have the male section should be upright so it can not collect dirt.
Ooo next I am going to scratch build a snow plough as it feels like I may need it xx
Chris
Hi,
Chris
Tis quite likely that any type if plug whichever way round you mount them could be an issue. I would suggest some connecting thin Nickel Silver Strip that is nailed with fine nails where they can make contacts. The strip in permanent position will tarnish but a gentle wipe with some fine emery should clean it enough for contact. But some graphite paste may help keep clean enough to not do that too iften.
