walkerart
Cowboy
Hi Dunny,
Thanks, yes any outside elec connections are an issue…. I’ve decided not to hinge my bridges just pull them out.
There are very good outside connections but I’m looking for a simple slot in if possible but a screw cap is ok.
I mostly feel my bridges will be out most of garden maintenance days then dropped in after.
My reason to drop the bar hinge idea was why have an upright track section sitting there in the wind or in the way moving things in the garden.
Yes if ya popping by easy lift but in truth you get used to working with what you make and a waist high track requires access if it’s using a space used everyday
So I feel most of the time it will be in train running, then some days just out.
Dunny will look at your points chum thanks, Oo good point I found by chance “bar keepers friend” home bargains
You mix the powder brush on yiur brass track wipe it off …. Bingo clean
It’s bonkers good and inly about £3
X
X
