LittleRedTrain
Hi all.
I've got an old Aristo Train Engineer (ART-5470, one of the two-channel versions) and as I no longer have a use for it on my G Scale (having switched to LGB kit) I thought I'd give it a go on a friend's HO garden railway to see if it was any use to him.
My understanding was that this should work, because as long as we only used a 12V DC power supply (in this case, the track output from an HO Gaugemaster controller) the TE receiver shouldn't output voltage/current levels that could damage HO scale motors.
However, when we tried it, we discovered that, despite the 12V DC input, the output was coming out on the meter as 19V DC, regardless of the setting of the handset.
We did try it with a fairly robust loco and it seemed to work fine, but he was loathe to try it further until we knew what was going on and whether there was a risk of burning out more sensitive locos (those with electronics onboard).
I did wonder if it had somehow gone into PWM mode, but the switch was most definitely in the 'linear' position.
Also, how does that explain the output voltage being higher than the input, I didn't think the receivers had a transformer in them.
Can anyone shed any light?
Many thanks
Daniel
Many thanks
Daniel
