do not use over the joiner clamps, you have a system that can help clamp dirt in the original joiner, and it does not touch the rails, just the joiner you are already striving to eliminate.
the issue with stock joiners is not pressure (which is the only thing an over the joiner clamp adds), but dirt ingress and oxidation.
Might as well as buy a jar of Lucas Magic Smoke.
Mine came in a bottle...Was that the real reason they changed to negative earth?Positive Earth. Specially made for built in obsolescence, see and hear your Morris 1300 be eaten by Rust Worm within days of making your purchase
God only knows. My 1300 was positive earthed and was rotten. Apparently they started being made as negative earth, but BMC, in their wisdom, changed it. What advantages positive earth has, I've no idea, but it obviously isn't worth ruining the car forGenuine question, I never knew what caused that change
Drill out the "dimple" on the bottom of the rail joiner and then pull it off laterally with pliers.Does anyone have a method to remove fishplates from LGB points without breaking the plastic ties?
On my plates, there is a little 90 degree flange (part of the fishplate) which sits in the first plastic sleeper. If you pull the plate out it will tear the plastic (that's the problem). I event been able to find the other thread Greg....Drill out the "dimple" on the bottom of the rail joiner and then pull it off laterally with pliers.
Look at post 4 on this thread where I have linked my method as seen on YouTube.Does anyone have a method to remove fishplates from LGB points without breaking the plastic ties? I am talking about the points that have spot weld conductivity straps that prevent the rail sliding along the sleepers.
Normally this will straighten as it is SHARPLY pulled, however ensure the track is held firmly. Thought for points I do prefer just to bend the sides away.On my plates, there is a little 90 degree flange (part of the fishplate) which sits in the first plastic sleeper. If you pull the plate out it will tear the plastic (that's the problem). I event been able to find the other thread Greg....
