TINY 3D build
ge_rik
Knowing my interest in attractive little locos, one of my correspondents suggested I take a look at a quirky little loco built by Stephen Lewin in 1868 and which eventually ran on the 3' 9" gauge Fayles Tramway in 1906. It was originally named CORFE but when it arrived at Fayles they appropriately renamed it TINY.
Source: George Moon Collection
It's taken me a while to draw, print out the parts and start construction and a fair bit of tweaking and fettling has been required, but I am slowly getting there.
I've modified the powered chassis I've used for a couple of other builds which uses a GA25-370 gear motor, using Bachmann 24.5mm dia metal wheels. I tend to avoid 3D printing loco wheels - it somehow doesn't feel right. Fortunately, it turns out that the original loco had solid wheels with spoke detail moulded on, so I printed wheels inserts to represent them.
Still a bit more work to be done - printing out some of the finer detailing, painting and installing the batteries and electrics, but it is taking shape.
Rik
Very nice:inlove: Is the Russel in the background of the original photo, it ended up down Swanage way I seam to recall?
Hi
Not sure. The only other loco on the line was a Manning Wardle 0-4-0 called THAMES, so I assume it was that loco. What happened to it when the line closed in 1945, I'm not sure.
Rik
At least you now have them! :worried: :blush:
In-joke (at my expense..) I had mis-typed the postcode.
Amazing how one digit discrepancy in the postcode can make such a difference. Even after I phoned Royal Mail and asked them to correct the postcode it still bounced back and forth between Nantwich and Warrington twice more before I managed to intercept it at Nantwich Delivery Office. If I hadn't, no doubt it would have continued to bounce back and forth. Interestingly, when I picked it up, someone had scribbled out the wrong part of the postcode and corrected it. However, they couldn't change the QR code on the label which is presumably what Warrington's machines kept using.
Anyway - all worked out OK in the end.....
Rik
Rik
Love technology, I always when taking off labels to shred them include the. Barcode and QR code. Perhaps the person that scrubbed out the Postcode should have done them as well, wonder the computer did not pick it up. Perhaps they still use the Horizon system!
Just a bit of general human common sense would be best in these cases. Mind you I suppose when The Bomb is finally launched, the chances are the AI system won't recognise the delivery address and send it back and forth for all eternity
