Street Lamp sort-of-things!
liam0404
9 Oct 2014
117
Hereford
Hello,
I'm looking to place some street lamps or similar style around my layout at like 1 metre intervals to give it some light in the evenings.
Wiring is simple, all in parallel, however, I'm struggling to find any lamps or ideas on how to make some.
Anyone got any ideas or photos they could pass on please?
Gizzy
36,212
2,296
63
Cambridgeshire
You could also try Garden Centres?
I had some LED powered Gas Lamps which I brought from another forum member.
However, they didn't fare too well outdoors so some were re-used on my indoor layout, Hardyard....
tramcar trev
22 Jan 2011
11,577
8
Canberra, Australia
trevs-tramway.blogspot.com
http://trevs-tramway.blogspot.com.au/2011/11/lights-and-poles.html?q=lights
http://trevs-tramway.blogspot.com.au/2012/12/goose-neck-lights.html?q=lights
http://trevs-tramway.blogspot.com.au/2012/12/happy-christmas-to-all.html?q=lights
Maybe a few ideas there....
3,551
What period/style are you after?
For a modern (urban) style, someone on here used the balls from roll-on deodorants.. One hole, a plastic tube, and a LED.
If you browse for dolls house fittings, you can find a period-style bracket lamp.. These can be modified to make them into a post-lamp. - Either with, or without, the bracket..
Also worth looking around the house / garage / shed for small odd-shaped bits you can use to make lamp-heads from..
I have had some success with up-market tooth-brush containers (before everything went 'shrink-wrap'). Cut into sections about 12 mm thick, a top from thick plastruct with shaped edges, Plastruct pole offset to one end, with a LED hot-glued in the fitting.
Anything with an oval/rectangular profile of a suitable size really..
Sure others will chip-in with ideas..
liam0404
9 Oct 2014
117
Hereford
I'd quite like the lamps to be in scale, not garden/solar style ones (a bit too big)
The old American style that had the oval top with the bulb underneath, opposed to a period style, is the type I'm after.
mike
Master at annoying..
4,477
Rossendale
i made mine, from leds, and crew caps, and wooden dowling..
liam0404
9 Oct 2014
117
Hereford
That's pretty much exactly what I want, except black poles not brown, thanks!
Is that just solder you have holding the lamp on?
And what is the cap bit from?
mike
4,477
Rossendale
hi, you can paint the wooden dowles, black.. no, thats the legs of the L.E.D. ..the wires feeding them are runnning up the pole in a grove i cut into it.. glued in place.. the caps are tube caps, from b+q.. the poles are simplely pushed into holes in the ground..
Steve
I didn’t say it was your fault, I said I was b
1 Jan 1970
29,027
285
D.I.L.L.I.G.A.F
Liam, or just buy a few LGB Piko lights every once in a while you can get a bargain on ebay ect ..
stockers
3,795
66
Nr. Ashford, Kent. England.
How about these.
http://pendleburymodels.com/wp/shop/lamppost-wall-mounted-12volt
tramcar trev
22 Jan 2011
11,577
8
Canberra, Australia
http://www.ebay.com.au/itm/H67-8-model-lampposts-White-light-200mm-height-12V-/160890165855?pt=AU_Toys_Hobbies_Model_Railways&hash=item2575cd1a5f
http://www.ebay.com.au/itm/6-six-LGB-Model-Power-7-5-Tall-Lited-Frosted-Sq-Street-Light-w-Brass-Pole-NEW-/311122899173?pt=Model_RR_Trains&hash=item48705eb0e5
http://www.ebay.com.au/itm/6-SIX-LGB-Model-Power-7-5-Tall-Lited-Ball-Street-Lights-Converted-w-Esso-Signs-/311118848999?pt=Model_RR_Trains&hash=item487020e3e7
http://www.ebay.com.au/itm/6-SIX-LGB-Model-Power-7-5-Lited-Ball-Street-Lights-Converted-w-Station-Clocks-/141435671588?pt=Model_RR_Trains&hash=item20ee391424
http://www.ebay.com.au/itm/12-LGB-Model-Power-7-5-Tall-Lited-Frosted-Sq-Street-Light-w-Brass-Pole-NEW-/141427646850?pt=Model_RR_Trains&hash=item20edbea182
DaveB2
7 May 2011
330
10
That sounds about like my attempt
https://www.gscalecentral.net/buildings-bridges-lineside/platform-lights-on-the-cheap/
which will give you one, or many of these
jeremy.viewing
15 Aug 2014
327
37
Souldrop
www.facebook.com
I have just built some using the Chinese e-bay lamps. Mentioned by Stockers.  Bought them from
http://www.ebay.co.uk/itm/111075781650?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I used plastistrut styrene tube and plasticard for the fabrication.
Jeremy
tramcar trev
22 Jan 2011
11,577
8
Canberra, Australia
Ohhh they look very nice
