Railcar bonnet
ge_rik
1,245
Cheshire
www.riksrailway.blogspot.com
Anyone know where I can puchase a bonnet assembly for a railcar/railbus. I'm wanting to do a kitbash using some bits and pieces I've got from an Andel Ashover coach to build something resembling an early Model T Ford type of railbus - a bit like this:
Anyone know of a source?
Rik
dragon
Video. Photography. Garden railways.
1
Rik
I think Paul( minimans ) had some. Try PMing him. He is coming to England soon.
Granitechops
Narrow Gauge 1/12th scale on 45mm</br>Quarrying &
7
Sunny Devon Uk
I have still got some that Paul sent over a couple of years ago, but they are not like the ones in your photo more american style see if I can dig them out
ge_rik
1,245
Cheshire
That would be great - I can always adapt them. Whilst I could make something from plasticard or wood, I'm not sure how I could reproduce the louvres or the grille
Rik
3Valve
Railways; Air cooled VW's; Soul Music
286
Shropshire
I think I've got a surplus Hartland Mack bonnet if it's of any use (basically the same bonnet as Doug mentions above.
ge_rik
1,245
Cheshire
I've had a quick look at a pic of a Mack and I think I could bash it by adding a Cambrian radiator to the front. Shall we PM to discuss terms?
Rik
treetop
Model boats, trains and gliders.
1 Sep 2010
57
Christchurch New Zealand
My 1:24 scale scratch built (including wheels) NZR Model T rail car.
The body panels and bonnet are made from thin brass sheet.
The radiator grill is brass gauze mounted in a wooden frame.
The bonnet louvers are represented in the following way.
Pairs of holes were drilled at the top and bottom of each louver.
Thin wire ?staples? were fed through the holes their ends bent over on the inside.
Filler was then applied around the edges of the wires. This was sanded, once set,
to form an even fillet shape.
Doug
Live Steam, scratch building
8
West Herts
Et voila, here is one i made earlier (well, still in progress really!!)
minimans
Trains, Planes, Automobiles & Shooting
222
67
San Francisco Bay Area
Glad there's still some of my old lnes around but I stoll have a few somewhere if needed
3Valve
286
Shropshire
Rik
No probs Rik, got your PM.
ge_rik
1,245
Cheshire
Absolutely brilliant, Doug. I doubt my efforts will look enywhere near as elegant or well finished. I recognise the parentage of the body.
What did you use for power BTW?
Rik
ge_rik
1,245
Cheshire
I could do with another one as I'm intending to have two running back to back (I have an end to end line).
Will PM
Rik
Doug
8
West Herts
Power is a £1.50 motor/gearbox from Maplin
Doug
8
West Herts
ge_rik said:
And wheels from GRS?
Rik
Yep, wheels from GRS, they just push on the axle coming out of the gearbox. Perfect fit
ge_rik
1,245
Cheshire
That's really helpful - thanks - and looks impressive. Not sure if I have the skills which you clearly possess but will certainly have a bash (which tends to be my modus operandi) if all else fails.
Rik
ge_rik
1,245
Cheshire
