maxi-model
CoggesRailway said:I have some flexi track that i pre bent, but not very well so they have a degree of tension on the joins... would any of these clamps bring these to alignment.
Are you in need of a rail bender ? I could lend you my GRS one. It has rollers for both LGB and Tenmille code 332 rail. If your rails were put through a bender there would salways be a bit, about 1 inch, at either end that had no curvature. If your rails were radiused reasonably accurately then you the would always be joining "straight" with "straight". You would also minimise the risks of derailments due to poor rail alignments at the join. I could post it to you and pick it up on your open day in August.
Max.
