James Day
Guano Corner Rly - Runs weekly - Guano permitting
Dear All,
I embraced EPL Technology back in the 1980s. I followed the system as it developed and soon got rid of all my solenoids.
My trains could now switch themselves, using the on board magnets and the wonderful 1700 Track Contacts. I quite liked them. The were neat and clipped to the track like the signals, catenary masts and cable clips.
Obviously the EPL range continued to develop and the mechanism itself went through several evolutions, as did the add on switch, the control boxes and then regrettably the wretched reeds.
The revised style LGB reed - 17100 is a horribly delicate thing that seems ridiculously fragile. I loathe the way it clips to the track (until the clips break) and am not crazy about the way the cables go in. several of mine have needed to be shown love, affection and a soldering iron to get them back to work. The bases are the most annoying thing as they seem to break very easily. Years ago LGB would sell you any bits that you wanted to repair, or make your own stuff, these days your lucky if you even get a reply.
I have tried making my own , which was reasonably successful, but I like the clip together nature of LGB and having recently used up a stack of stuff extending the line, I needed to re-stock on a few essentials.
I decided there and then never to buy any more 17100s. I searched out some new, or nearly new 1700s, from a number or sources, but given their age and potential use, they could be an unknown quantity. I wanted something new that was readily obtainable and then I saw the relatively new PIKO 35272.
This does exactly the same job as the 17100 and much loved 1700, but looks a lot more positive than the former.
Mine came from Gaugemaster at 12.75 GBP each, but Glendale are offering them at 10.50 GBP when they have them. These make them cheaper than the loathsome 17100, no matter where you buy them.
I like the way the whole `gubbins` of the thing sits within the box, and the way the lid clips firmly in place. I don`t like the lack of any indication as to which terminal is which, but the connections are the same way round as LGB and do the same job, so I am sure I can cope. The wings that clip them into the track base look worryingly like the 17100, except that on the PIKO version these are more meaty, which hopefully means stronger?
There are no drain holes in the base of the box containing the circuit board with the reed and the instructions emphasize that they should not be allowed to sit in water, but placed somewhere dry, where water can pass over them and drain away. Sounds sensible to me!
I am installing my newly acquired pair on the loop of the station on my new extension. Looking forward to see how they cope over the coming months!
Here is a link to them on the PIKO web site: http://www.piko.de/pdb_en/index.php?page=detail&grand_id=100&parent_id=4&child_id=2&id=35272
Here is link to pdf of the instruction sheet: http://www.piko-shop.de/is.php?id=13151
Below are some images, showing the three types of reed together and individually. Finally there is an image showing the PIKO reed installed on the layout.
I can confirm that it snaps in very positively. There is a thin tongue on each of the two clip wings that holds the reed firmly between the rail and the sleeper web. It is rock solid when in place. The lid snaps on positively too.
Recommended ++++ Provided that these two do not go horribly wrong in their trails, I will definitely be buying more of these!
James
James
