Ralphmp
Sure - picture attached (for those who've not used these before, you crimp a wire into one of the silver terminals and then simply push this into the back of the "latch" block. The connectors are designed to be spring loaded so then when you push the "latch" onto the pins the tension ensures good contact and helps retain the "latch" in place.
However, Gizzy's approach of soldering direct to the pins and covering with heat shrink etc. is an excellent one (which I may end up adopting if I can't satisfactorily weatherproof the "latch" connector).
