Ralphmp
I have a Pola windmill that a friend is kindly building for me. I have the Pola motor drive that goes with it and this requires 12 - 16 volts AC with a current draw of 60mA.
From memory - I can’t read the manual due to eyesight issues at the moment - I recall you can set a Massoth Switch decoder for continuous output and limit the output voltage as well. If I’m right, I guess it should be possible to connect the windmill motor to the decoder so I can then turn it on/off using an address on my Navigator.
Hoping someone can confirm if I’m right or not and, if someone has already done something like this, perhaps offer guidance on which CVS to adjust.
I have a spare 4 channel decoder and 1 channel decoder I could use - not fussed which type, whichever is easiest for me to tell my friend how to set up.
Thanks
Thanks
