Recently upgraded to a new
Piko analog throttle (35002). Cleaned my brass track and was up and running generally ok. Had a derailment and then it stopped working. I realized the red led was blinking which supposedly indicates a short or overload. I reset and the loco went a short way then stopped- same issue. Then every time I reset and tried again it would immediately trip. Hooked up my old Pino throttle which has no breaker and it works fine. Any ideas? Thanks!
Test the loco for possible short inside:
1. Remove the power cable from the track but still connected to your Piko unit;
2. Turn the loco upside down, wedge it between a couple pillows;
3. Turn on the power to about 5 volts and hold the ends of the two cables to the first set of wheels, then the electrical slider shoes, and then the other set of wheels..........do this each set to see if the motor works. Let it run a few minutes on each wheel set and slide shoes set to see if you get a motor stoppage, or no motor movement. If you find an issue, then it's a strong possibility you've got a short inside the motor block that needs to be fixed........could even be the motor.
Are you using the Piko 35024 Transformer 120V / 24V / 5A that's made to be used with the Piko 35002 Throttle? If you're using some power supply device, its specifications could be causing the problem. If you are using the associated Piko power supply, and if you loco doesn't have a short, the problem could be your Piko Throttle and/Piko Supply........which would seem unlikely. But if you want to get further technical advice regarding your issue, you can contact Piko of America, San Diego CA:
Phone: 619-280-2800
Toll-Free: 877-678-4449
Fax: 619-280-2843
info@piko-america.com
Hours: Monday - Friday 9:00AM - 5:00PM Pacific
