Given most European NG lines tend not to be trans national, never mind continental, then the lack of "sleepers" does not surprise me. Particularly as LGB's, and others, home market tends to be "mittel" European. But I expect to be proved wrong. I could see the demand for some to be used in engineering works trains. Yes other nations like South Africa and in the far east have extensive NG trans national networks that would have a need, and that would work out near 1000 mm gauging. But their modelling is again very much dependent on home market demad. Of course the scale 1.22.5 is shared by Gauge 3 The Gauge '3' Society, British Standard Gauge, Large Scale Garden Railways which models std gauge running on 64 mm gauged track. Garden Railway Specialists have been past champions of this modeling sector but seem to be tailing off their product range. MaxI have not come across any sleeper coach in G scale.
45 mm gauge in 1:22.5 scale translates to 1000 mm gauge in real life. There are plenty of sleeper coaches in this gauge in reality.
Why G scale has none?
In this hot weather we can close the curtains and pretend it is night time and run sleeper coaches indoorSleeper coaches are best for long distance journeys, they also tend to run at night when most gscale owners don’t operate.
Oh yes forgot that, travelled Delhi to Jodhpur then a week or so later Jodhpur to Udaipur both in MG sleepers. That was back in 1987.Sleeper coaches on meter gauge are common in South East Asia.
Before India converted its entire network to broad gauge, there were meter gauge sleeper coaches in mainlines.
Japan + parts of Africa use cape gauge, which is only slightly wider (1067 mm) and there are plenty of sleeper coaches in this gauge.
Agree that it is rare in Europe due to smaller sizes of countries.
I measured with Playmobil figure lying on floor, in a Playmobil panorama coach, there is enough space to create sleepers.
To create a realistic sleeper coach, one needs a long 2x2 axles coaches like Panorama coach.
Layout can be of 2 types
[1] traditional sleeper with corridor on one side
[2] business jet type seating converted to beds - similar to Panorama coach layout. The table goes down and seats fold to make bed
In this hot weather we can close the curtains and pretend it is night time and run sleeper coaches indoor![]()
I like the sound of Sir Arthur, British eccentricity at it's very best!Interestingly, Sir Arthur Heywood built a four berth sleeping car to run on his 15" gauge Duffield Bank Railway. That only ran around his garden.
I can't find a picture of the real thing. I think there's a full scale replica on the Perry grove Railway, but you can get a model of it from MG Models in Gn15 (and his 8 seater Dining Car)
Rik
Worth reading up about his 'minimum gauge' railway - of course, this level of eccentricity requires a substantial amount of wealth behind it, much like the founding of the RHDR.I like the sound of Sir Arthur, British eccentricity at it's very best!
Yes the rich are eccentric, the oiks are idiotsWorth reading up about his 'minimum gauge' railway - of course, this level of eccentricity requires a substantial amount of wealth behind it, much like the founding of the RHDR.
Mind you without the rich, their eccentricities and their enquiring minds, we would be a lot poorer.Yes the rich are eccentric, the oiks are idiots
I have at least a dozen LGB coaches which have toilet compartments.This is a crude model in Blender for sleeper coaches. The dimension of coach is similar to that of Playmobil Panorama coach.
After drawing this I realized forgot to add toilet.
Having said that, never seen toilet in G scale trains. I have a Playmobil campervan which does have a toilet though.
In reality, sleeper coaches on metre gauge systems are quite uncommon, for reasons already noted above.
Amazing what a small piece of land with a hotel on it, in Melbourne, featuring an “artistic” painting of Chloe can finance when inherited!Worth reading up about his 'minimum gauge' railway - of course, this level of eccentricity requires a substantial amount of wealth behind it, much like the founding of the RHDR.
Is that a Royal Flush?The Claptowte Railway has several coaches fitted with toilets, you could say they are flush with them.
