justme igor
Hot sand can help, but your pipe will be to hot to handle.
In the best case scenario with 65C you will manage. worst case it must be 80C
Before bending take in consideration that there is a "memory" in the material, so bent it a little bit more than you want.
But why not take the playwood pieces cut them up into 5cm pieces width of a full lenght of that sheet.(244cm)
you can easy bend them.
Btw for those kind of curves, why dont you get a string for you desired curve, place a spike in the grass, attach the string to it and at the other end a pencil?
