Massoth Reverse Loop Module Reset
Clive
Drama - acting, Woodwork, G Scale, railways
Help!! I've followed meticulously the wiring diagram for a Massoth Reverse Loop Module but the loco stalls and a short is caused when it enters the loop. Is it possible to reset the module please, and if so, can someone give me a step by step guide as to how?
My layout is DCC. The layout is basically a straight line with two balloon loops - each loop quite some distance ( 50m) from the other. The module in question did work really well until I mixed up the wiring whilst repairing the track.
Many thanks.
Clive
PS I've wired it with the two short isolated track wired to the module sensors
I don't think it is resettable, as it is just a relay.
I would check the wiring again, against the other unit....
Yes those were my thoughts, when I did my pals one I cut short 2mm or so bits of Black and Red wire insulation to put on the wire in logical to me ways so that I could work out the wiring, all of course pre done and notated for fitting. Tis so easy to get things wrong with a Massoth revercing unit.
