Lichen
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
I would like to use lichen on my layout but I do not like how it crumbles apart. Any advise on how to soften it up and keep it soft. Anybody seen plastic lichen? Thanks all.
4,997
Lichen can be soaked Glycerine to stop it being crumbly. Trouble is so far as I remember from using the process moons ago Glycerine is quite expensive and I am not sure what would happen to it if you used the Lichen outdoors. Perhaps a good dunking in PVA and Glycerine May work?
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
Thanks for the response on my question.
stevedenver
255
I use lichen a fair amount in some pola buildings, ground shrubs, planter box fill.
It has a look, and, not a great one, imho, unless augmented with flower material, or, finer shrub and tree stuff.
Its cheap, common in ho scenery supplies.
I use it in my pola stuff because its cheap and replaceable.
It dries out, but, if untouched, seems to more or less work. A spritz will rehydrate it. Seems the color fades with dryness and returns with moisture.
It seems too, I tried the glycerine thing decades ago, and, never kept it up. Messy, and interferes with adherence as i recall.
I also use lichen in my dry denver n scale layout, stuffed into utah desert mountain crevices, bottoms of arroyos, etc., I find that it stays, and, should the basement humidity rise, as it does on occasion, the lichen softens. Otherwise its dry, but seems to work anyway.
I havent found a solution to keep it soft, other than high humidity.
