LGB on board decoder diagrams
Neil Robinson
This diagram for both single and twin motor locos seems to have been well received on another thread.
Apparently it's not easy to find these diagrams with an internet search so I thought it may be useful to repeat the image here.decoder diagrams.jpg
Yes, they are very useful - having them here should make them easy to find in future, thanks!
It would be nice to find out what the "multi-purpose" socket does, especially since the example picture on the other threads shows something plugged into it.
Hi Greg,
On the rear of many LGB loco's are sockets, ostensibly, to supply power for coach-lighting..
If you remove the track connections on a loco, it can also be used as a 'fast and dirty' way of feeding battery-power into a loco for test purposes..
Hi Greg,
Indeed, many people don't just use it for testing, but as a permanent way of feeding power to the loco from a trailing battery car. It's not the best method, but it DOES work and is easy to do.
It should always be remembered that unless the track pickups are also removed or disconnected in some way, as Phil says, then when you're feeding power in via the socket you will actually be feeding the battery power to the whole track!
The plug from the decoder board to the rear socket is usually light blue in colour, unlike the rest of the CT plugs which are usually white. No idea why this is, but it's a useful identifier.
Apparently it's not easy to find these diagrams with an internet search so I thought it may be useful to repeat the image here.View attachment 244806
I’m new… bought an LGB 2080D and want to convert to battery power and RC using Piko 35040. 2080D has 2 circuit boards, one in front of the cab and the other in the “coal bin,” connected by a ribbon cable (4 wires). I don’t see how to remove the rear circuit board to have access to rear lights and backup light. Any help greatly appreciated.
