LGB 24450 RhB Ge2/4 No 221
J
jonothan
16 Feb 2010
106
1
Hi Guys
I bought this loco from Tim at Arcadia on Saturday. I noticed that the steps under the right hand cab door (under the non-working door on the model) seem to be missing on both sides. Is this correct? Does anyone else own one of these?
Thanks
Jonothan
J
jonothan
16 Feb 2010
106
1
Thanks, John.
Strangely enough, it doesn't really answer my question, because I looked on Ebay before starting this thread and found photos of a model just like mine. The photo you've linked to on the LGB website is a pre-production model. I am looking for more first hand experience of this production run.
stockers
stockers
79
Nr. Ashford, Kent. England.
P
phils2um
Phil S
11 Sep 2015
295
90
Ann Arbor, Michigan
The one I've got does not have steps. Perhaps the right side doors were welded shut in the 1950's rebuild on the original? I'll check for some photos on the RhB web site.
Phil S.
P
phils2um
Phil S
11 Sep 2015
295
90
Ann Arbor, Michigan
Could not quickly find a photo of 221 but 222 shows up about 2 minutes into the "Bahnparade in Pontresina von 09.06.2018" on YouTube. It does have steps at both ends of the locomotive. The RhB roster shows that 221 was retired in 1998.
Phil S.
P
phils2um
Phil S
11 Sep 2015
295
90
Ann Arbor, Michigan
Well my speculation about welded doors was just that! I did find a photo of 221 as rebuilt. It still had doors and steps on both sides of each cab. Now I'm wondering why Märklin started leaving them off.
Phil S.
PaulRhB
PaulRhB
Looks like a mistake by LGB as they should be there right up to withdrawal
https://flic.kr/p/otFMEC I guess they figured as the door is moulded shut it didn’t need steps! Funny they put the handrails on though ;)
Try asking the shop to get spares.
J
jonothan
16 Feb 2010
106
1
I think I’ve found the answer. If you look at the earlier prototypes, they have tanks/cylinders under the main body at each end on both sides which the earlier models have as well. In the modified prototype 221 and 222, those on the right of each side are missing as they were presumably redundant. So they’ve been omitted on the production model LGB 24450 too. They weren’t omitted on the preproduction models. I think that, in the model, the steps are secured by a tab underneath the tank/cylinder do they have been omitted from the model too. Does this make sense?
Reactions: mike
D
DougLN
NARROW GAUGE RAILWAYS
5 Jul 2010
66
DIDCOT,OXON
I brought a 2nd hand one at GRS in 1995 ( it was 2045 ref then). Mine has cab steps at both ends/sides. It still runs very well.
J
jonothan
16 Feb 2010
106
1
I just looked at the 2018 catalogue...
Reactions: DougLN and mike
M
mole
ipswich
The two models I have of that loco the one shown in the pictures and the lighter brown one with the signature on the doors have steps on both ends
P
phils2um
Phil S
11 Sep 2015
295
90
Ann Arbor, Michigan
My 24450 has steps at both ends - as of about three weeks ago. Thanks John, for suggesting the spares! The steps mount quite easily.
The position for the steps is precisely fixed by locators moulded into the chassis, pic 1. (The two holes seen photo 1 are a result of my attaching the steps; they were not there originally.) The steps were put in place, then I drilled two pilot holes through both the steps and chassis, pic 2. The pilot holes in the steps were enlarged to through holes and the steps secured with two screws, pic 3.
1)
2)
3)
Pic 4 below shows the complete job. I did fix the whistle after I took the shot!.
Phil S.
Reactions: PaulRhB
