nico
mike is right dont use pea gravel,i used 5mm limestone graveldutchelm said:The biggest mistake on my line was to use pea gravel. It will not hold the track in place & is a liability as ballast. You need gravel or grit with corners to lock together & hold the track in place. The later sections of mine are laid in horticultural grit.RSB said:Many thanks for all the replies so far, they have all been very helpful and informative.
So far I think I am likely to go with digging a trench, lay weedproof membrane and then fill with ballast / pee shingle.
The track I am going to use is LGB, would 10mm pea shingle be ok for ballast?
