The finished storage bins, stocked up and ready to go. The first bin is for the storage of Calor Gas bottles. The centre bin is a holding store for filled sacks of coal and logs. The end bin is for split logs.
The first bin is for the storage of Calor Gas bottles. You can click on the link below to see how I made them. More bottles will be added as they become available
Claptowte Railway - Calor Gas Bottles - G Scale Central
The centre bin is used as a holding store for filled sacks, ready for delivery. The coal sacks are resin castings manufactured by Modeltown. These sacks were also used for the Claptowte Railway Coal Staithes and the load for the 1941 Plymouth Pick-up truck. As with the pick-up truck, two of the tops of the coal sacks were drilled and scraped out to provide space to add a filling of split logs. You can click on the links below to see the Plymouth Pick-up and the Coal Staithes.
Claptowte Railway - 1941 Plymouth Pick-up - G Scale Central
The Claptowte Railway - Coal Staithes - G Scale Central
The sack trolley is also identical to the one displayed in the coal staithes. They are a 3D printed item from SLR. They were printed to 16mm scale which made them slightly tall for G Scale, so I reduced the height of the handles.
The pile of empty coal sacks was scratch built. I had an old sheet in the garage which I used as a dust sheet. The doubled over and stitched hem at one end was exactly the right width for an empty coal sack. I cut off and trimmed a length of this hem which I then cut to suitable lengths. I soaked the pieces with a solution of white PVA glue in order to stiffen them. When they were almost dry they were folded over and glued together into a pile. When this was completely dry they were spray primed and painted to match the resin coal sacks.
The last bin is used for split logs. The logs are sawn and split from offcut branch of Acer in the garden, 1/24 scale white metal axe from S&D Models. ..
