45mm gauge spoked wheels
M
Moonraker
24
South Australia
I am scratch building a 45mm gauge locomotive which needs spoked tender wheels which are as near as possible to 43mm diameter. Number of spokes not important. Can't find any anywhere. Can anyone make any suggestions please?
Regards
Peter Lucas
MyLocoSound
802
71
Walsall May be your best bet in UK. He does 3’6” finished castings which is 42 inch pretty close, you may get exact with careful turning of the blanks.
852
Tamworth, Staffs.
I think we need the prototype size, and whether 'G' or something finer?
M
Moonraker
24
South Australia
Thanks but I don't have any machine tools so blanks are not viable for me. I am an electronics/3D printing/laser cutting person.
After more searching I found that the Slaters S9851 appears to be almost spot on so I will try those. Expensive but they seem to be the only option. They are intended for 10mm/foot gauge 1 so does anyone know if they will have problems running on my G scale LGB and Aristocraft track?
Regards
Peter Lucas
MyLocoSound
Gizzy
Gizzy
32,739
481
Cambridgeshire
I've a mate who runs G1 stock on LGB code 322 track, and they seem to work fine. He did replace all of his R3 points with R5 ones on the outer loop of his double track layout though for some of this stock....
Rhinochugger
Rhinochugger
Retired Oik (IBT)
885
North West Norfolk
Regards
Peter Lucas
MyLocoSound
Slaters' wheels will run fine on G scale track.
My scratchbuilt 2-6-2 uses Slaters' drivers
Rhinochugger
Rhinochugger
Retired Oik (IBT)
885
North West Norfolk
Finer flanges doesn't necessarily mean finer scale or finer track tolerances - the smaller flanged US Accucraft stock has the same back-to-back as G scale and most Gauge 1 stuff :nod: :nod: :nod:
As Greg routinely points out, flange dropping on points (turnouts) is the only issue, not much of a problem on bogie stock ;);)
M
Moonraker
24
South Australia
Thanks. I have ordered Slaters.
The photo shows the loco I am scratch building onto a modified Bachmann Annie chassis using laser cut 3mm mdf and 3D printing. It is a South Australian Railway YX class loco which is running on the Pichi Richi railway.
Regards
Peter Lucas
MyLocoSound
Reactions: trammayo
802
71
Regards
Peter Lucas
MyLocoSound
Nice looking Loco with typical Beyer Peacock looks. Almost like a Tender Isle of Man Loco sans Water Tanks, but Beyers did have a characteristic design. Battery Powered I presume with MLS Sound?
