DGE-Railroad
The Orchard Line
Given my printers workload at the moment Jimmy, I suspect it'll expire before it becomes availableSo when can you print me one![]()
The BR blue body awaits the arrows of indecision from Fox Transfers.
Although I'm fairly pleased with the colour, the hippy eco-PLA material doesn't seem to tolerate temperature fluctutations, which I'm assuming is what the terrible looking top part was affected by. That's a candidate for a reprint..
The cab appears to be on the wrong end !The BR blue body awaits the arrows of indecision from Fox Transfers.
Indeed it does...… or perhaps it has two right hand sides, and no left hand.The cab appears to be on the wrong end !
Are you sure?The cab appears to be on the wrong end !
The dibit on top near the cab should be behind the Radiator. I think the top bit has just been put on the wrong way round, simple error to make if not looking at an appropriate picture.The BR blue body awaits the arrows of indecision from Fox Transfers.
That's a better explanation.The dibit on top near the cab should be behind the Radiator. I think the top bit has just been put on the wrong way round, simple error to make if not looking at an appropriate picture.
Yep, that set of 4 grills should be at the other end.Are you sure?
I think the most prestigious duty ever afforded this class of loco was to be the off-stage pusher when the steam loco arrived on stage in the live theatre version of the Railway Children at Waterloo Station. The Stirling Single had smoke effect fake steam coming out of the front end, but in the background, you could hear the unmistakable burble of the diesel shunter.Siblings! I'm just waiting on some screws to attach the yellow rods. Tonights task is to wire on the sound and RC for a quick test tomorrow
I still want oneSiblings! I'm just waiting on some screws to attach the yellow rods. Tonights task is to wire on the sound and RC for a quick test tomorrow
Only if you print the radiator diagonallyI have seen a 3D printer with two print-heads...
Does this mean you could print the 'wasp-stripes directly?
Gargh!Oh dear, one of the yellow con-rods is upside down now![]()
Now you have done will you be doing 2 more for the Tinsley master and slave?View attachment 281649View attachment 281650View attachment 281651
Now waiting on a replacement battery - i foolishly left the last one switched on after being called away and it now resembles a zeppelin so has been disposed of![]()
I think I'll be scaling back my G scale interests for a bit to be honest, or at least shelving it for a while, while I concentrate on something bigger...Now you have done will you be doing 2 more for the Tinsley master and slave?
