Hi, just setting up a few points servos & wondered what type & size of wire is recommended from servo arm to points arm. Don't laugh, i found an old plastic/nylon chopping board that fitted perfect into a sleeper. Bit of sanding & some brown paint. "Perfect"
Hi, just setting up a few points servos & wondered what type & size of wire is recommended from servo arm to points arm. Don't laugh, i found an old plastic/nylon chopping board that fitted perfect into a sleeper. Bit of sanding & some brown paint. "Perfect" View attachment 301795 View attachment 301796
Hi Chris
I seem to recall using paperclip wire in the early days, but have since used 1.5mm brass rod in an outdoor setting. I would probably use phosphor bronze if I was using servos now with an omega loop or a zig zag to allow for a bit of expansion and contraction.
Rik
PS I'd just check all your stock through that servo mount to make sure your rather ingenious bracket doesn't foul any carriage or loco steps (don't ask how I know this ..... )
